はじめに
A guide on how to replace the speaker inside of a smartphone Doov v15.
Before
Make sure you have a replacement Speaker compatible with the Doov v15.
Work in a clean, well-lit area.
Use appropriate tools like a opening tool, Jimmy, screw driver , and Magnetic mat.
Ensure you have the necessary safety gear to protect your eyes and hands.
Back up your data and power off the phone before you start. For additional help please the step by step guide.
必要な工具と部品
Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
Onec you disconnect the battery now use iFixit Precision Bit Driver and iFixit Precision 4 mm Screwdriver Oval Drive Bit (0.5). Place the Screwdriver in the top of screw and rotate it clock wise until the screw comes out.
Remember to use magnetic mat to keep those tiny screw safe so that you will not lose it. Repeat the steps and unscrew all the screw.
Carefully disconnect any cables or connectors attached to it. Remove any screws securing the speaker in place. Gently lift the old speaker out of its position.
Replace the new speaker in the place of old speaker and with the help of soldering Gun connect all the cables and any connectors back.
