メインコンテンツにスキップ
Doov v15 Camera Replacement
必要な工具と部品
  1. Doov v15 Camera Replacement, Camera: 手順 1、 1の画像 1
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Camera Replacement: 手順 2、 3の画像 1 Doov v15 Camera Replacement: 手順 2、 3の画像 2 Doov v15 Camera Replacement: 手順 2、 3の画像 3
    • Use an ifixit opening tool to slide around the phones back cover, loosening it and allowing for an easy removal. It should easily separate from the chassis. Make sure to trace it around the entire phone.
    • Disconnect the Battery: Once the back casing is removed, the battery will be visible. Use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  3. Doov v15 Camera Replacement: 手順 3、 3の画像 1 Doov v15 Camera Replacement: 手順 3、 3の画像 2 Doov v15 Camera Replacement: 手順 3、 3の画像 3
    • Once you disconnect the battery, use the iFixit Precision Bit Driver and iFixit Precision 4 mm Screwdriver Oval Drive Bit (0.5). Start unscrewing each screw clock wise until they come out. Repeat the steps and unscrew all the screw.
    • Make sure to keep the screws together in a bag or magnetic mat to ensure they aren't lost or misplaced.
  4. Doov v15 Camera Replacement: 手順 4、 3の画像 1 Doov v15 Camera Replacement: 手順 4、 3の画像 2 Doov v15 Camera Replacement: 手順 4、 3の画像 3
    • After all screws are removed, use the iFixit opening tool to gently pry open and seperate the chassis.
    • Be cautious to avoid damaging internal components. Slide it around the phone to loosen it and gently remove the chassis.
  5. Doov v15 Camera Replacement: 手順 5、 3の画像 1 Doov v15 Camera Replacement: 手順 5、 3の画像 2 Doov v15 Camera Replacement: 手順 5、 3の画像 3
    • Locate and Disconnect camera. You will find the camera on top-left corner. Use jimmy to puff it and disconnect any cables or connectors.
    • Place a new camera and with the help of soldering Gun connect all the cables and any connectors back.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Elijah Taylor
メンバー登録日: 09/08/23
398 ポイント
2のガイドは作成済み
チーム
University of New Orleans, Team 5-3, McDonald Fall 2023 University of New Orleans, Team 5-3, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S5G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 79
