メインコンテンツにスキップ
Disassembling the Nintendo 64 (without special tools)
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Disassembling the Nintendo 64 (without special tools), Disassembling the Nintendo 64 (without special tools): 手順 1、 1の画像 1
    • You will need a kitchen lighter and a plastic pen shell, and you will want to do this outdoors to allow the plastic the burn into the air instead of trapping it in a room. Heat the tip of the empty pen shell until it melts into a glob.
  2. Disassembling the Nintendo 64 (without special tools): 手順 2、 1の画像 1
    • Stick the pen into one of the 6 holes on the bottom of the Nintendo 64. When it reaches the screw, press forcefully for about three seconds and then let go.
    • TIP: The circled hole has the smallest inner diameter, so if you mold your pen with this hole, you can remove the others without remolding if you are careful not to strip it.
  3. Disassembling the Nintendo 64 (without special tools): 手順 3、 1の画像 1
    • Allow the pen to reform and solidify around the screw for 4 to 5 minutes. If done correctly, the pen will mold completely around the specialized screw and grip it so that it can be twisted out.
  4. Disassembling the Nintendo 64 (without special tools): 手順 4、 1の画像 1
    • Grip the pen and, pushing down forcefully, begin to twist it loose (to the left) as if you were using an actual screwdriver. The screw should come out with the pen as shown in the picture if done flawlessly. If not, you can still manage to get the screw out without it molding completely.
  5. Disassembling the Nintendo 64 (without special tools): 手順 5、 1の画像 1
    • Repeat the melting and re-solidifying process 5 more times for the rest of the screws, and the console will be ready to be opened up for repair.
  6. Disassembling the Nintendo 64 (without special tools): 手順 6、 1の画像 1
    • Open the outer shell of the case if it is not already opened. For a how-to on that, go here.
  7. Disassembling the Nintendo 64 (without special tools): 手順 7、 1の画像 1
    • Once the case is off, turn your attention to the silver plate covering the green motherboard underneath. Begin unscrewing the screws connecting the plate to the motherboard.
    • Also remove the two smaller screws on the expansion slot.
  8. Disassembling the Nintendo 64 (without special tools): 手順 8、 1の画像 1
    • The motherboard is now free to be worked on.
終わりに
9 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Benjamin Donnelly
メンバー登録日: 10/29/13
1,282 ポイント
4のガイドは作成済み
チーム
University of Maryland, Team 1-6, Shastany Fall 2013 University of Maryland, Team 1-6, Shastany Fall 2013人のメンバー
UMD-SHASTANY-F13S1G6
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 18,134
