メインコンテンツにスキップ
Disassembling the Garmin eTrex Vista-H Outer Case
必要な工具と部品
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: 手順 1、 1の画像 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: 手順 2、 1の画像 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: 手順 3、 2の画像 1 Disassembling the Garmin eTrex Vista-H Outer Case: 手順 3、 2の画像 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: 手順 4、 2の画像 1 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: 手順 4、 2の画像 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: 手順 5、 3の画像 1 Disassembling the Garmin eTrex Vista-H Outer Case: 手順 5、 3の画像 2 Disassembling the Garmin eTrex Vista-H Outer Case: 手順 5、 3の画像 3
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: 手順 6、 1の画像 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: 手順 7、 2の画像 1 Disassembling the Garmin eTrex Vista-H Outer Case: 手順 7、 2の画像 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
終わりに
7 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Ryan Green
メンバー登録日: 10/17/10
93 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G30
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 4,982
