メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Push the back glass towards the top of the phone.
    • Push the back glass towards the top of the phone.
  3. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  4. Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  5. Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top  connector sheild. Using a plastic opener tool, pry up the battery connector.
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  6. Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
終わりに
3 の人々がこのガイドを完成させました。
Chandler Skinner
メンバー登録日: 2011年10月15日
3,721 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,961
