メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのiClickerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Disassembling iClicker Device, Disassembling iClicker Device: 手順 1、 1の画像 1
    • Behold the iclicker in all its interactive and educational beauty.
  2. Disassembling iClicker Device: 手順 2、 1の画像 1
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
  3. Disassembling iClicker Device: 手順 3、 2の画像 1 Disassembling iClicker Device: 手順 3、 2の画像 2
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
  4. Disassembling iClicker Device: 手順 4、 2の画像 1 Disassembling iClicker Device: 手順 4、 2の画像 2
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
  5. Disassembling iClicker Device: 手順 5、 1の画像 1
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
  6. Disassembling iClicker Device: 手順 6、 2の画像 1 Disassembling iClicker Device: 手順 6、 2の画像 2
    • Using a spudger, gently pry the battery connectors from the front panel.
  7. Disassembling iClicker Device: 手順 7、 1の画像 1
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
  8. Disassembling iClicker Device: 手順 8、 1の画像 1
    • The buttons can be easily removed from the front assembly sans spudger.
  9. Disassembling iClicker Device: 手順 9、 1の画像 1
    • Don't lose the small LED cover sitting precariously in the front panel.
  10. Disassembling iClicker Device: 手順 10、 1の画像 1
    • Your iclicker is now disassembled.
作成者
4人の作成者と共同で作成されました。
Brady Cabe
2,743 ポイント
2のガイドは作成済み
コメント 1 件
What is an iClicker ?
furbies - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 7,841
