はじめに
This guide will show you the quickest way to remove the front of the device so you can get to deeper parts of the device.
必要な工具と部品
Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
This step deals with the indicated area of the device.
Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
Rotate device 180 degrees and repeat for other side.
Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
3 の人々がこのガイドを完成させました。
2 件のコメント
Excellent and clear instructions, thankyou. Only trouble is the CD Changer device door is not opening! As I have not actually carried out the Front Panel removal at present I am hoping my problem will expose itself when I complete your instructions in practicality. Thanks again. Denis.
Thanks a lot for the guide! I was able to fix my problem of cassettes playing too slow. You rock!
