メインコンテンツにスキップ
Disassembling Wii Balance Board
必要な工具と部品
  1. Disassembling Wii Balance Board, Floor Unit: 手順 1、 1の画像 1
    • Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
  2. Disassembling Wii Balance Board: 手順 2、 1の画像 1
    • Remove the foot holders and place them on the side
  3. Disassembling Wii Balance Board: 手順 3、 1の画像 1
    • Remove the four feet and place them on the side
  4. Disassembling Wii Balance Board: 手順 4、 1の画像 1
    • Remove these #1 Philips screws, and leave them in their counterbores
  5. Disassembling Wii Balance Board: 手順 5、 1の画像 1
    • Lift grey shell off and place to the side to reveal:
    • ADC and Logic board
    • Bluetooth module
    • Strain gauges
    • Battery holder
  6. Disassembling Wii Balance Board: 手順 6、 1の画像 1
    • The ADC and Logic board contains:
    • Bluetooth module
    • Power button connector
    • Battery and sync button connector
    • Strain gauge wheatstone bridge connections
    • The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
終わりに
15 の人々がこのガイドを完成させました。
Pete Marchetto
メンバー登録日: 01/25/11
667 ポイント
2のガイドは作成済み
5 件のコメント
Great stuff Pete, being able to fix the wifi board got me mucho street cred with " her indoors " and lots of other goodies that go along with that
HENRY - 返信
Can I take out the battery box without removing the bottom?
Richard Merchant - 返信
No, you can't. You will have to follow this procedure completely.
paulo lima -
Thank you! I was able to fix our 10 year old balance board.
the kids think I’m a roakstar, for now anyway.
lisadubya - 返信
is there schematics for the power pcb
Josué Hernandez - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 37
今までの合計 12,203
