メインコンテンツにスキップ
Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
必要な工具と部品
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: 手順 1、 3の画像 1 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: 手順 1、 3の画像 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: 手順 1、 3の画像 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 2、 2の画像 1 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 2、 2の画像 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: 手順 3、 1の画像 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 4、 3の画像 1 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 4、 3の画像 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 4、 3の画像 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: 手順 5、 2の画像 1 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: 手順 5、 2の画像 2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 手順 6、 2の画像 1 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 手順 6、 2の画像 2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 7、 1の画像 1
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: 手順 8、 2の画像 1 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: 手順 8、 2の画像 2
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 手順 9、 1の画像 1
    • Remove both screws holding the retaining plate with the logic board.
終わりに
作成者
1人の作成者と共同作成されました。
Gaetan
メンバー登録日: 12/26/12
9,574 ポイント
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 1,995
