ツール
工具は必要ありません。
パーツ
パーツは必要ありません。
  1. Use a large plastic opening tool along the rear panel: There are 4 clips to release. There are 4 clips to release.
    • Use a large plastic opening tool along the rear panel:
      • There are 4 clips to release.
  2. Slide the cover along the plastic frame. Slide the cover along the plastic frame.
    • Slide the cover along the plastic frame.
  3. Slide off the largest plastic pieces.
    • Slide off the largest plastic pieces.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Bend the second small plastic piece to release it from the rubber piece. Now you can slide it out. Now you can slide it out.
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  6. Slide out the hard drive as shown in the picture Make sure to slide as shown or you may damage the USB bridge logic board.
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  7. Remove the 4 rubber piece from the plastic frame at each corner. Remove the 4 rubber piece from the plastic frame at each corner.
    • Remove the 4 rubber piece from the plastic frame at each corner.
  8. Remove the rubber piece from the  SATA/USB bridge logic board.
    • Remove the rubber piece from the SATA/USB bridge logic board.
まとめ
Gaetan
メンバー登録日: 2012年12月26日
9,337 ポイント
18のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 14
今までの合計 978
