メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのOregon Scientific Ultra Thin Weather Stationを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Disassembling Weather Box Oregon BAR800, Disassembling Weather Box Oregon BAR800: 手順 1、 1の画像 1
    • Weather Box, front side
  2. Disassembling Weather Box Oregon BAR800: 手順 2、 3の画像 1 Disassembling Weather Box Oregon BAR800: 手順 2、 3の画像 2 Disassembling Weather Box Oregon BAR800: 手順 2、 3の画像 3
    • Rear side
  3. Disassembling Weather Box Oregon BAR800: 手順 3、 1の画像 1
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
  4. Disassembling Weather Box Oregon BAR800: 手順 4、 3の画像 1 Disassembling Weather Box Oregon BAR800: 手順 4、 3の画像 2 Disassembling Weather Box Oregon BAR800: 手順 4、 3の画像 3
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
  5. Disassembling Weather Box Oregon BAR800: 手順 5、 1の画像 1
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
  6. Disassembling Weather Box Oregon BAR800: 手順 6、 3の画像 1 Disassembling Weather Box Oregon BAR800: 手順 6、 3の画像 2 Disassembling Weather Box Oregon BAR800: 手順 6、 3の画像 3
    • Internal view
作成者
2人の作成者と共同で作成されました。
Andres
メンバー登録日: 11/14/13
110 ポイント
1ガイドが承認済み
10 件のコメント
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - 返信
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel -
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 3,222
