メインコンテンツにスキップ
Disassembling Trek 820 Tire Removal from Wheel
必要な工具と部品
  1. Disassembling Trek 820 Tire Removal from Wheel, Tire: 手順 1、 1の画像 1
    • Locate the valve stem and remove the valve stem cap if one is present.
  2. Disassembling Trek 820 Tire Removal from Wheel: 手順 2、 1の画像 1
    • Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
    • Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
  3. Disassembling Trek 820 Tire Removal from Wheel: 手順 3、 2の画像 1 Disassembling Trek 820 Tire Removal from Wheel: 手順 3、 2の画像 2
    • Insert the flathead screwdriver, or another sturdy, long object, between the edge of the tire and the wheel rim.
    • Be careful not to damage the inner tube when inserting and moving the screwdriver or other tool. The inner tube is fragile and may be pinched between the wheel rim and tool.
    • Work the edge of the tire out of the wheel rim using a screwdriver, pulling the edge of the tire away from the center of the wheel and out of the rim.
  4. Disassembling Trek 820 Tire Removal from Wheel: 手順 4、 3の画像 1 Disassembling Trek 820 Tire Removal from Wheel: 手順 4、 3の画像 2 Disassembling Trek 820 Tire Removal from Wheel: 手順 4、 3の画像 3
    • Continue around the wheel rim until the whole tire is free from the rim. Now you may separate the tire from the wheel.
    • Be careful not to damage the valve stem as you pull the tire and inner tube off of the wheel rim together.
  5. Disassembling Trek 820 Tire Removal from Wheel: 手順 5、 2の画像 1 Disassembling Trek 820 Tire Removal from Wheel: 手順 5、 2の画像 2
    • Remove the inner tube from the tire by simply pulling it from the tire carcass.
終わりに
For tire reinstallation, simply follow these steps in reverse order.
作成者
11人の作成者と共同で作成されました。
Kaveh Karimiyanha
メンバー登録日: 09/24/12
813 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S1G1
5 メンバー
9のガイドは作成済み
コメント 1 件
Be very careful using a screwdriver to unseat the tire as it is very likely you will pinch and thus ruin the tube. Better to buy several tire levers at any bike shop - they are inexpensive and made for this job.
John Sinclair - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 1,138
