メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Translucent Rubber Flashlight Battery Power Component
  1. Disassembling Translucent Rubber Flashlight Battery Power Component, Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 1、 1の画像 1
    • Remove light mechanism from body containing battery. Twist light bulb (red circle) counterclockwise while holding base of flashlight (black circle).
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 2、 1の画像 1
    • Angle body of flashlight until two AA batteries fall out. Store battery components.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 3、 1の画像 1
    • Pull off rubber chassis of flashlight. Peel back rubber on battery side of flashlight first (red circle). Grip remaining rubber (black circle) and pull off plastic/metal body in direction counter to opening.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 4、 1の画像 1
    • Remove metal apparatus containing button switch first by bending piece in arc shape. Carefully pull out clipped tip as shown.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 5、 2の画像 1 Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 5、 2の画像 2
    • Using the freed tip, detach the bottom of the metal switch connected to the spring of the grounded/negative end where the AA batteries are located (circle).
    • Push metal end into square hole so clip detaches from battery spring (circle). Pull out rest of clip avoiding spring, so metal switch freed from body.
    FixBotに聞いてみる
    コメントを追加
  6. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 6、 2の画像 1 Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 6、 2の画像 2
    • Spring connected to flashlight base removed using tip of metal switch (circle) hooking and pulling into opening.
    • Initiate battery switch disassembly (circle).
    FixBotに聞いてみる
    コメントを追加
  7. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 7、 3の画像 1 Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 7、 3の画像 2 Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 7、 3の画像 3
    • The switch mechanism disassembly removes the button attached to the lid (red circle) from the grooves (blue circle) containing the switch components.
    • Next, remove the spring first and then metallic, grooved pressure plate which contained the spring (red circle) using hand.
    • Finally, remove metal connections of battery switch by lifting holes (red circle) off containment piece.
    FixBotに聞いてみる
    コメントを追加
  8. Disassembling Translucent Rubber Flashlight Battery Power Component: 手順 8、 1の画像 1
    • The battery components of translucent flashlight completely disassembled.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Phillip Phung
メンバー登録日: 01/19/12
666 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G18
4 メンバー
12のガイドは作成済み
1件のガイドコメント
thanks a lot that really help. especially the on off switch 2 spring part. mine was a rear switch though
John Doe - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 53
今までの合計 3,354
