はじめに
Hey all,
Today I will show you how to open the Toshiba satellite C55-A5285/C55-A1J2. It is the same same computer inside and you will see how to remove/replace different parts of the laptop and repair it. Or you can upgrade the laptop.
In this project I had to clean out ( dust and others) the inside of the laptop. But I will show you the rest as well.
This will work on a Toshiba made for the American market as well as the one for the European market as well. Both the C55-A5285 and the A1J2 are both same on the inside.
必要な工具と部品
First of all remove the battery.
remove the bottom plate of the ram and HDD.
now remove the hdd screw ( red circkle)
lift up the HDD
remove the ram by clicking the levars to the outside
remove the screw , and use a spudger to remove the dvd bay. ( slide it out)
remove the screw of the keyboard, orange circkle
turn the laptop again and remove the keyboard.
use a isesamo to click the keyboard off the laptop. the "click levars"( 6 of them) are under number 0 , between left arrow and ctrl, alt gr , space bar, windows button and alt and ctrl(left)
after clicking the keyboard loose, lift the lid of the connector socket up and remove the flex cable. you can see a picture in step 6.
now you will see 2 connectors and 7 screws under the keyboard.
remove the screws and gently remove the 2 connectors from the connectors. like always do it gently.
the orange circkles are the screws to remove the mainboard in a later step
the red squares are the connectors of the mouse pad and powerboard
the blue square is the connector from the keyboard.
use a spudger or little flathead screwdriver to open the lid of the connectors.
first screws : 3 screws in the HDD compartiment.
screws at the side , also see the next step for the rest of the screws.
remove the last screws
then : slide your spudger or isesamo between the bottom plate and upper plate to remove the case. you will hear clicks. be gently while sliding
gently remove the plate.
after opening you'll see the mainboard or like we call it here in Belgium : the motherboard.
in this step we will show you how to remove the fan and the cooling tubes and pads for cleaning or renewing.
there are 8 screws and 1 connector
remove the screws ( 1 screw is not on the pictures, you ll find it at the bottom of the fan) but unscrew them simultaneous.
remove the connector ( see picture 2 ) using an IC extractor
remove the cooling tubes and fan.
clean the pads using isopropyl alcohol. you will see pieces (remnants ?) of old thermal paste.
use gloves
you can also renew /upgrade the cpu, just use a flathead screwdriver to open the cpu socket.
removing or replacing the Mainboard :
first remove the LCD connector: do it very gently, there are a lot of tiny thin wires, they are very breakable. you see this in picture 2, if you have to replace the whole screen, i don't have pictures of this in this guide, but we have other guides that show you how to or you can find these here at ifixit.com
remove the screw you see in picture 3
in these 3 pictures: dc jack in picture one, + the connector, and the usb pcb. if you have to replace the dc jack, be gently with the connector.
second picture : wifi module. always remember the color code ( black and white)
third picture : mousepad and screws.
11 の人々がこのガイドを完成させました。
