メインコンテンツにスキップ
Disassembling Toshiba NB205 N330PK Back Panels
必要な工具と部品
  1. Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: 手順 1、 2の画像 1 Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: 手順 1、 2の画像 2
    • Using the Phillips #0 in the bit driver, carefully loosen and remove the single 5mm screw.
    • With the retaining screw removed, lift the panel upwards to separate it from the netbook.
  2. Disassembling Toshiba NB205 N330PK Back Panels: 手順 2、 2の画像 1 Disassembling Toshiba NB205 N330PK Back Panels: 手順 2、 2の画像 2
    • To replace the panel, do step 1 in reverse:
    • Align the panel slots in the appropriate grooves and set in place.
    • With the bit driver, replace the screw to secure the RAM panel.
  3. Disassembling Toshiba NB205 N330PK Back Panels: 手順 3、 2の画像 1 Disassembling Toshiba NB205 N330PK Back Panels: 手順 3、 2の画像 2
    • Using the bit driver and the Phillips bit, remove both of the panel's retaining screws.
    • With the screws removed, lift the panel in the designated direction, as depicted in photo, for removal.
    • The hard drive is located beneath this cover and is now accessible.
  4. Disassembling Toshiba NB205 N330PK Back Panels: 手順 4、 2の画像 1 Disassembling Toshiba NB205 N330PK Back Panels: 手順 4、 2の画像 2
    • To replace the hard drive panel, do step 3 in reverse:
    • Place the panel back in its original position and press down.
    • If the hard drive was removed or replaced during this process, improper installation may prevent the hard drive panel from sitting in the slots properly.
    • With the bit driver and Phillips bit, replace the two retaining screws to secure the cover plate in place.
終わりに
作成者
5人の作成者と共同で作成されました。
Mason McCaskill
メンバー登録日: 10/18/13
1,000 ポイント
9のガイドは作成済み
チーム
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G2
3 メンバー
27のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 961
