はじめに
Removing the back panel from the Toshiba AT1304T
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
必要な工具と部品
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
終わりに
ある他の人がこのガイドを完成しました。
