パーツ
パーツは必要ありません。
  1. Flip the phone over so that the screen is facing down.
    • Flip the phone over so that the screen is facing down.
  2. Push the gray lever up towards the top of the phone. Pull up on the battery pack and completely separate it from the phone.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Locate the 5 screws around the back casing. Use a three-prong screw bit to remove all 5 screws
    • Locate the 5 screws around the back casing.
    • Use a three-prong screw bit to remove all 5 screws
  5. Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  6. Separate the two cases.
    • Separate the two cases.
  7. Use the plastic opening tool to remove the motherboard from the front case.
    • Use the plastic opening tool to remove the motherboard from the front case.
まとめ
ある他の人がこのガイドを完成しました。
Austin Shores
メンバー登録日: 2013年10月18日
301 ポイント
3のガイドは作成済み
チーム
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S13G5
3 メンバー
12のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 95
