メインコンテンツにスキップ
Disassembling Speak And Spell Case
必要な工具と部品
  1. Disassembling Speak And Spell Case, Case: 手順 1、 2の画像 1 Disassembling Speak And Spell Case, Case: 手順 1、 2の画像 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: 手順 2、 1の画像 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
終わりに
bushing
メンバー登録日: 04/23/10
10,250 ポイント
13のガイドは作成済み
コメント 1 件
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 4,960
