パーツ
パーツは指定されていません。
  1. Flip the toy over, so that the keypad is facing away from you. Remove two Phillips-head screws.
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
まとめ
bushing
メンバー登録日: 2010年04月23日
9,421 ポイント
13のガイドは作成済み
コメント1件
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 20
今までの合計 3,625
