この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
もう少しです!
終わりに
