メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel
必要な工具と部品
  1. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Back Panel: 手順 1、 1の画像 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 2、 1の画像 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 3、 1の画像 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Power Button: 手順 4、 1の画像 1
    • Remove the stylus from the device.
  5. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 5、 3の画像 1 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 5、 3の画像 2 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 5、 3の画像 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
  6. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Side and Bottom Panel: 手順 6、 2の画像 1 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Side and Bottom Panel: 手順 6、 2の画像 2
    • Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
    • Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
  7. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 7、 2の画像 1 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: 手順 7、 2の画像 2
    • Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
終わりに
作成者
3人の作成者と共同で作成されました。
Zachary Jeffers
メンバー登録日: 10/13/14
412 ポイント
4のガイドは作成済み
チーム
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G4
4 メンバー
22のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 56
今までの合計 647
