メインコンテンツにスキップ
Disassembling Sony Ericsson w600i Back Housing
必要な工具と部品
  1. Disassembling Sony Ericsson w600i Back Housing, Disassembling Sony Ericsson w600i Battery Cover: 手順 1、 1の画像 1
    • Grip the lower portion of the back of the phone and slide downwards.
  2. Disassembling Sony Ericsson w600i Back Housing, Battery: 手順 2、 1の画像 1
    • Lift battery at the rounded notch near the bottom of the phone.
  3. Disassembling Sony Ericsson w600i Back Housing, Back housing: 手順 3、 1の画像 1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  4. Disassembling Sony Ericsson w600i Back Housing: 手順 4、 1の画像 1
    • Swivel the phone open.
  5. Disassembling Sony Ericsson w600i Back Housing: 手順 5、 1の画像 1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  6. Disassembling Sony Ericsson w600i Back Housing: 手順 6、 1の画像 1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  7. Disassembling Sony Ericsson w600i Back Housing: 手順 7、 1の画像 1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  8. Disassembling Sony Ericsson w600i Back Housing: 手順 8、 2の画像 1 Disassembling Sony Ericsson w600i Back Housing: 手順 8、 2の画像 2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  9. Disassembling Sony Ericsson w600i Back Housing: 手順 9、 3の画像 1 Disassembling Sony Ericsson w600i Back Housing: 手順 9、 3の画像 2 Disassembling Sony Ericsson w600i Back Housing: 手順 9、 3の画像 3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  10. Disassembling Sony Ericsson w600i Back Housing: 手順 10、 1の画像 1
    • The back housing is now disassembled, and the swivel assembly is revealed.
終わりに
作成者
3人の作成者と共同で作成されました。
Beau Blanchard
メンバー登録日: 09/30/12
20 ポイント
6のガイドは作成済み
チーム
University of Maine, Team 1-5, Diaz Fall 2012 University of Maine, Team 1-5, Diaz Fall 2012人のメンバー
UMAINE-DIAZ-F12S1G5
1 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 455
