メインコンテンツにスキップ
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
必要な工具と部品
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: 手順 1、 1の画像 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 2、 2の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 2、 2の画像 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 3、 1の画像 1
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 4、 2の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 4、 2の画像 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 5、 2の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 5、 2の画像 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 6、 1の画像 1
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 7、 2の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 7、 2の画像 2
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 8、 2の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 8、 2の画像 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 9、 3の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 9、 3の画像 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 9、 3の画像 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 10、 3の画像 1 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 10、 3の画像 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 手順 10、 3の画像 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Christine Becker
メンバー登録日: 10/28/13
101 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013人のメンバー
UMAINE-DIAZ-F13S1G13
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 3,563
