このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
Grasp the top cover and gently remove it from the camera body.
この手順は未翻訳です。 翻訳を手伝う。
Flip the LCD Assembly around the edge of the camera
Use the plastic opening tool to gently pry up the black tab locking the large ribbon cable to the battery housing.
Grasp the LCD display with your fingers and gently pull the large ribbon cable out of the connector.
The LCD display is now detached from the camera.
