メインコンテンツにスキップ
Disassembling Sony Clie PEG-SL10
必要な工具と部品
  1. Disassembling Sony Clie PEG-SL10, Disassembling Sony Clie PEG-SL10: 手順 1、 1の画像 1
    • Start by holding your Sony Clie PEG-SL10 face-up in your hand.
  2. Disassembling Sony Clie PEG-SL10: 手順 2、 1の画像 1
    • Turn over your Sony Clie and unlock the cover slide lock.
  3. Disassembling Sony Clie PEG-SL10: 手順 3、 1の画像 1
    • After unlocking the cover slide lock, remove the cover and set aside.
  4. Disassembling Sony Clie PEG-SL10: 手順 4、 1の画像 1
    • Turn your Sony Clie face-up.
    • Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
  5. Disassembling Sony Clie PEG-SL10: 手順 5、 1の画像 1
    • Remove the front case by gently lifting away from the device.
  6. Disassembling Sony Clie PEG-SL10: 手順 6、 1の画像 1
    • Turn the Sony Clie face down and open the back case by prying open the left side of the device.
    • It will open like a book connected by hinges on the right side.
  7. Disassembling Sony Clie PEG-SL10: 手順 7、 1の画像 1
    • Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
  8. Disassembling Sony Clie PEG-SL10: 手順 8、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
  9. Disassembling Sony Clie PEG-SL10: 手順 9、 1の画像 1
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  10. Disassembling Sony Clie PEG-SL10: 手順 10、 1の画像 1
    • Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
  11. Disassembling Sony Clie PEG-SL10: 手順 11、 1の画像 1
    • Pull the power cable from the socket located above the upper right side of the battery harness.
  12. Disassembling Sony Clie PEG-SL10: 手順 12、 1の画像 1
    • Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
  13. Disassembling Sony Clie PEG-SL10: 手順 13、 1の画像 1
    • Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
  14. Disassembling Sony Clie PEG-SL10: 手順 14、 1の画像 1
    • Gently pull out the clips to remove the top power cables from the motherboard.
終わりに
作成者
5人の作成者と共同で作成されました。
Steve
メンバー登録日: 10/18/11
9 ポイント
1ガイドが承認済み
チーム
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011人のメンバー
JMU-ALLEN-F11S1G4
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 18
今までの合計 1,745
