メインコンテンツにスキップ
Disassembling Sirius Stiletto 100 Circuit Board
必要な工具と部品
  1. Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: 手順 1、 2の画像 1 Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: 手順 1、 2の画像 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Circuit Board: 手順 2、 2の画像 1 Disassembling Sirius Stiletto 100 Circuit Board: 手順 2、 2の画像 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Circuit Board: 手順 3、 3の画像 1 Disassembling Sirius Stiletto 100 Circuit Board: 手順 3、 3の画像 2 Disassembling Sirius Stiletto 100 Circuit Board: 手順 3、 3の画像 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Disassembling Sirius Stiletto 100 Circuit Board, Circuit Board: 手順 4、 1の画像 1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Disassembling Sirius Stiletto 100 Circuit Board: 手順 5、 2の画像 1 Disassembling Sirius Stiletto 100 Circuit Board: 手順 5、 2の画像 2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Disassembling Sirius Stiletto 100 Circuit Board: 手順 6、 1の画像 1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Staten
メンバー登録日: 03/09/12
69 ポイント
1ガイドが承認済み
チーム
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,915
