メインコンテンツにスキップ
Disassembling Siemens A56 Motherboard Metal Frame
必要な工具と部品
  1. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 手順 1、 3の画像 1 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 手順 1、 3の画像 2 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 手順 1、 3の画像 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  2. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 手順 2、 3の画像 1 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 手順 2、 3の画像 2 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 手順 2、 3の画像 3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  3. Disassembling Siemens A56 Motherboard Metal Frame: 手順 3、 3の画像 1 Disassembling Siemens A56 Motherboard Metal Frame: 手順 3、 3の画像 2 Disassembling Siemens A56 Motherboard Metal Frame: 手順 3、 3の画像 3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  4. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 手順 4、 3の画像 1 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 手順 4、 3の画像 2 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 手順 4、 3の画像 3
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Joseph Casey
メンバー登録日: 03/26/14
409 ポイント
4のガイドは作成済み
チーム
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G6
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 181
