メインコンテンツにスキップ
  1. Push and hold the button on the back toward the direction of the arrow to unlock the battery. Lift and remove the battery from the back of the phone. Lift and remove the battery from the back of the phone.
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Using a push pin, pull out the plug on the back, located under the antenna. You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  5. Use a plastic opening tool to pry the back panel along the edges. You may need to apply some force when prying.
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  6. While removing the back panel, take out the rubber cover on each side. While removing the back panel, take out the rubber cover on each side. While removing the back panel, take out the rubber cover on each side.
    • While removing the back panel, take out the rubber cover on each side.
まとめ
Yemane
メンバー登録日: 2013年04月13日
7 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-41, Amido Spring 2013 Cal Poly, Team 10-41, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G41
4 メンバー
12のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 207
