この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you to access the inner workings of the phone by removing the outer shell. After gaining access to the internal hardware, you should be able to replace items such as:
* Screen
* Keypad
* LogicBoard
* And More
必要な工具と部品
Press the battery release button located on the back of the phone.
With the button depressed, pull down on the battery protector to remove it from the phone.
With the battery removed, four (5.75mm) screws that hold the outer case together are visible (circled in picture).
