メインコンテンツにスキップ
Disassembling Sanyo Katana Eclipse X Outer Casing
必要な工具と部品
  1. Disassembling Sanyo Katana Eclipse X Outer Casing, Back Panel: 手順 1、 2の画像 1 Disassembling Sanyo Katana Eclipse X Outer Casing, Back Panel: 手順 1、 2の画像 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X Outer Casing: 手順 2、 1の画像 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Disassembling Sanyo Katana Eclipse X Outer Casing, Casing: 手順 3、 1の画像 1
    • This task can be difficult. This phone has several specialized screws that are engineered to prevent removal.
    • With the battery removed, four (5.75mm) screws that hold the outer case together are visible (circled in picture).
  4. Disassembling Sanyo Katana Eclipse X Outer Casing: 手順 4、 1の画像 1
    • Using your "Damaged Screw Remover", remove the screws from their current positions.
    • Once the screws are removed, the phone can be split apart.
    • You may need to wiggle the case a bit in order to get it loose
    • The case is now open.
終わりに
作成者
6人の作成者と共同で作成されました。
Scott Kelley
メンバー登録日: 11/10/11
101 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-3, Diaz Fall 2012 University of Maine, Team 1-3, Diaz Fall 2012人のメンバー
UMAINE-DIAZ-F12S1G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 460
