はじめに
This guide illustrates how to remove the battery from a Sanyo Katana Eclipse X.
パーツ
パーツは必要ありません。
  1. Press the battery release button located on the back of the phone.
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
      • The phone's battery will now be exposed.
  2. Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
      • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
まとめ
Thomas Scaggs
メンバー登録日: 2012年10月15日
209 ポイント
2のガイドは作成済み
チーム
University of Maine, Team 1-3, Diaz Fall 2012 University of Maine, Team 1-3, Diaz Fall 2012人のメンバー
UMAINE-DIAZ-F12S1G3
5 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 167
