メインコンテンツにスキップ
Disassembling SanDisk Sansa Fuze
必要な工具と部品
  1. Disassembling SanDisk Sansa Fuze, Sansa Fuze MP3 Player: 手順 1、 1の画像 1
    • Pry open and pop the clips. Note that the bottom two clips are held in with a little bit of rubbery glue. Don’t rip the face off too quick since there is a ribbon cable you need to disconnect.
  2. Disassembling SanDisk Sansa Fuze: 手順 2、 1の画像 1
    • Remove ribbon cable connect to the face plate. Lift the face off and flip the brown ribbon release flap on the connection on the board. (The flap in this picture is black, opposite the cable. Lift the edge that is closest to you in the picture in order to release the cable.)
  3. Disassembling SanDisk Sansa Fuze: 手順 3、 1の画像 1
    • Remove two (in some versions there are 3) screws holding the board down
  4. Disassembling SanDisk Sansa Fuze: 手順 4、 2の画像 1 Disassembling SanDisk Sansa Fuze: 手順 4、 2の画像 2
    • Remove LCD by releasing the 4 clips on each side of the LCD, be carefully to not damage the LCD
  5. Disassembling SanDisk Sansa Fuze: 手順 5、 1の画像 1
    • Carefully flip the LCD over and disconnect the LCD cable from the board
  6. Disassembling SanDisk Sansa Fuze: 手順 6、 1の画像 1
    • Remove battery. The battery is taped down with a little double sided tape
    • If you are replacing the battery just apply a soldering iron to the battery connections on the board and gently pull them off..
    • To re-attached the new battery by reheating the old solder and reconnecting the new battery wires
    • Link to a battery Battery Clerk - Sansa Fuze battery
    • PLEASE NOT IF REPLACING THE BATTERY YOU DO NOT NEED TO REMOVE THE BOARD :)
  7. Disassembling SanDisk Sansa Fuze: 手順 7、 1の画像 1
    • Remove the board by lifting on the left side first as to work around the on off switch.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
James
メンバー登録日: 03/17/13
493 ポイント
1ガイドが承認済み
チーム
Everything iPod Everything iPod人のメンバー
Community
63 メンバー
3のガイドは作成済み
6 件のコメント
Hi,
I've lost the brown ribbon release flap. So my ribbon cable has no connection most of the time. Is there any chance to replace this with something else? Or get a new connector?
Thanks,
Simon
moony - 返信
Sep 7 is backwards - device power button is on the right side, release motherboard on that side first. Otherwise thank you for the guide!
Killen Prophet - 返信
Hi; I can't reconnect the ribbon cable in step 2, please help anyone. I tried regular tweezers, they are too big and the cable is too short.
Pat - 返信
Thanks so much for this post! It was a big help in getting my screen fixed and everything re-connected! Love my sansa fuze!
Penney H - 返信
Fixed my First Sandisk Fuse! I have had probably 10 over the last 15 years and finally got to repair one! Great Advice!
J.J. - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 25
過去 30 日: 98
今までの合計 19,314
