メインコンテンツにスキップ
Disassembling Samsung TFT Color YP-T7J USB Connector Dock
必要な工具と部品
  1. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: 手順 1、 2の画像 1 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: 手順 1、 2の画像 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 2、 2の画像 1 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 2、 2の画像 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 3、 3の画像 1 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 3、 3の画像 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 3、 3の画像 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: 手順 4、 2の画像 1 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: 手順 4、 2の画像 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 5、 2の画像 1 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 5、 2の画像 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 6、 3の画像 1 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 6、 3の画像 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 6、 3の画像 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Dylan Peters
メンバー登録日: 10/18/13
409 ポイント
4のガイドは作成済み
チーム
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G8
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 587
