メインコンテンツにスキップ
Disassembling Samsung TFT Color YP-T7J Removing the Front Cover
必要な工具と部品
  1. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: 手順 1、 2の画像 1 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: 手順 1、 2の画像 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 2、 2の画像 1 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 2、 2の画像 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 3、 3の画像 1 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 3、 3の画像 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 3、 3の画像 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: 手順 4、 2の画像 1 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: 手順 4、 2の画像 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  5. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 5、 3の画像 1 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 5、 3の画像 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 5、 3の画像 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  6. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 6、 1の画像 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  7. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 7、 2の画像 1 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 手順 7、 2の画像 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jason Farr
メンバー登録日: 10/21/13
353 ポイント
3のガイドは作成済み
チーム
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G8
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 242
