メインコンテンツにスキップ
Disassembling Samsung SyncMaster 205BW Monitor
必要な工具と部品
  1. Disassembling Samsung SyncMaster 205BW Monitor, Disassembling Samsung SyncMaster 205BW Monitor: 手順 1、 1の画像 1
    • Back of the monitor. Remove the two screws at the top of the stand.
  2. Disassembling Samsung SyncMaster 205BW Monitor: 手順 2、 1の画像 1
    • Stand and monitor body now separated.
  3. Disassembling Samsung SyncMaster 205BW Monitor: 手順 3、 1の画像 1
    • Front of monitor body. Push on the silver edge to unhook it from the panel.
  4. Disassembling Samsung SyncMaster 205BW Monitor: 手順 4、 1の画像 1
    • Silver edge cover unlocked. Note that a cable connects to the body. Hold the panel and remove the black cover at the back. You can then disconnect the cable.
  5. Disassembling Samsung SyncMaster 205BW Monitor: 手順 5、 1の画像 1
    • Silver edge removed and placed under the body with metal back. Black cover removed. The front panel cable connects to the bottom right of the body. Remove it. Remove the metal cover on top right by pulling it slightly on the edge at the top. This allows the two hooks on the slanting edge of the metal bracket to be unhooked.
  6. Disassembling Samsung SyncMaster 205BW Monitor: 手順 6、 1の画像 1
    • Remove the cover on the right to reveal two cables with four connectors. There is also a connector under the air holes which is now shown above the bracket with words "LVDS". Remove them all to free the metal bracket with the circuit boards from the panel.
  7. Disassembling Samsung SyncMaster 205BW Monitor: 手順 7、 1の画像 1
    • The metal bracket with circuit boards. The smaller circuit board: * two screws (bottom left, bottom right) * four screw extenders at the sides of the connectors The larger circuit board: * two black screws (bottom left, top middle) * one silver screw with washer that holds a metal strip and circuit board (top left)
  8. Disassembling Samsung SyncMaster 205BW Monitor: 手順 8、 1の画像 1
    • Circuit board with unfastened screws pointing to the holes they were in.
  9. Disassembling Samsung SyncMaster 205BW Monitor: 手順 9、 1の画像 1
    • Disassembled pieces.
  10. Disassembling Samsung SyncMaster 205BW Monitor: 手順 10、 1の画像 1
    • Circuit boards zoomed in.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
YIP Chi Lap
メンバー登録日: 04/22/11
282 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 38
今までの合計 8,126
