メインコンテンツにスキップ
Disassembling Samsung Galaxy S Blaze Whole Device
必要な工具と部品
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Disassembling Samsung Galaxy S Blaze Whole Device: 手順 1、 1の画像 1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 2、 1の画像 1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 3、 2の画像 1 Disassembling Samsung Galaxy S Blaze Whole Device: 手順 3、 2の画像 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 4、 1の画像 1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 5、 1の画像 1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 6、 1の画像 1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 7、 1の画像 1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 8、 3の画像 1 Disassembling Samsung Galaxy S Blaze Whole Device: 手順 8、 3の画像 2 Disassembling Samsung Galaxy S Blaze Whole Device: 手順 8、 3の画像 3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 9、 1の画像 1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: 手順 10、 1の画像 1
    • All of the parts are seen here.
終わりに
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jake Best
メンバー登録日: 03/05/15
261 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 11-1, Blackburne Winter 2015 Sam Houston State, Team 11-1, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S11G1
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 724
