はじめに
This is the first few steps for disassembling the DVD player.
パーツ
パーツは必要ありません。
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  5. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  6. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
まとめ
3 の人々がこのガイドを完成させました。
Mitchell Hart
メンバー登録日: 2011年01月21日
834 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G30
4 メンバー
8のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,336
