はじめに
Disassembling the mouse is very easy and should take about 10-15 minutes.
必要な工具と部品
Use the tweezers to lift the bottom slider, if you use your nails you might just lift the slider, instead of all the glue with the slider.
Remove all 4 screws.
There is 1 at the bottom under the slider.
The top ones are under the letter A from BASILISK and the other one between the EE from HYPERSPEED.
The last one is on top of the last 4 digits of the IFETEL number.
First remove battery, after that, lift it from the bottom using your nail or a prying tool from the gap at the bottom. Open it carefully, since there are wire connectors. Carefully disconnect from the plastic to avoid damage, DO NOT PULL FROM THE WIRES.
If you need to remove the board, you need a 00 Philips bit for the screws on the board and a 1 Philips bit for the screws on the side buttons, other than that, you have full access to the board.
3 の人々がこのガイドを完成させました。
