ガイド紹介
In this guide, we will go through disassembling your device's case to access internal components
パーツ
パーツは指定されていません。
  1. Use a philips #00 screwdriver to unscrew both 4.064mm screws at the top of the device which hold it together. Use a philips #00 screwdriver to unscrew both 4.064mm screws at the top of the device which hold it together.
    • Use a philips #00 screwdriver to unscrew both 4.064mm screws at the top of the device which hold it together.
  2. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  3. Press a plastic opening tool into the space between the front and back portions of the case. Run it along the perimeter of the device to unhook the many plastic tabs.
    • Press a plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the many plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover so be careful when separating
終わりに
2 の人々がこのガイドを完成させました。
Stephen Radachy
メンバー登録日: 2015年03月17日
807 Reputation
5のガイドは作成済み
チーム
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G5
2 メンバー
12のガイドは作成済み
One Comment
boi this it too easy
murphy mcgrath - 返信
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 600
