メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Disconnect the power supply cord from the outlet.
    • Disconnect the power supply cord from the outlet.
  2. Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
終わりに
3 の人々がこのガイドを完成させました。
Samuel
メンバー登録日: 2012年09月26日
142 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G12
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,970
