メインコンテンツにスキップ
はじめに
How to replace the LCD screen if it is broken or cracked.
パーツ
パーツは指定されていません。
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  4. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  5. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  6. Locate the black plastic strip under the screen above the white plastic strip.
    • Locate the black plastic strip under the screen above the white plastic strip.
  7. Pull up both sides of the black piece up about a mm.
    • Pull up both sides of the black piece up about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
まとめ
Dani
メンバー登録日: 2010年06月24日
21 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 3-3, Johann Summer 2010 Cal Poly, Team 3-3, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S3G3
2 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,532
