はじめに
In this guide we will be removing the diffuser and the bottom panel of this lamp. This is necessary to access the electronic boards.
必要な工具と部品
WARNING Make sure that the power cord of the lamp is unplugged and thus you will not encounter any live wire that tend to hurt...
Stand the lamp up on a table and slightly press on the top gray panel of the lamp.
20 の人々がこのガイドを完成させました。
12 件のコメント
Hi,
The guide was very helpful as I just received such lamp for checking from one friend.
I would make only make one correction: you do not have to cut the plastic snap-ins, none of them.
If you use an IPhone opening toll kit, with those plastic levers as here:
[リンクされた製品が存在しない、もしくは無効: IF145-000]
then you can open it easy, without any scratches.
im wondering whether its possible to overwrite the wake sounds...
Chris Mair - 返信
Thank you so much for this guide. Was just about to give up on my lamp and buy and inferior led version when I found this.
These steps also work for the 3740 but the tabs holding the shade on (steps 8-10) are a different style. More like the ones on the bottom trim piece. Had to really work them and muscle that part off.
My ceramic bulb holder is severely corroded to the point where the light will only turn on if you jiggle the bulb. A little sad to see that the wires going to it are permanently attached on both ends. Now that the whole thing is apart. I'm going to see if I can source a new bulb holder and splice it onto the top...
Hello,
Thanks for this "opening guide". I have too the main fuse on the "Sparrow Power PCB" out of service. Well, I think I have 2 fuses out of service : the first in square plastic has reference "T1.25AL 250V" so I can find new one, but the second was a blue disk on PCB with "FU1" label. Anyone know the value for this FU1 component (fuse I suppose)? Thank in advance for your help!
to disassmble the diffuser you can stick 8 wooden clothes pegs in the snaps to hold them open simutaneously. then you can easily pull the diffuser of without damage. therefore it ist better to lose the three bottom srews afterwards, so that the inner part sticks as one peace together.
Thank you very much for this guide!!
Tow of the buttons on my Wake up light are not working / got mixed up in their function: 1) Light up is only changing the clock upwards 2) select + button is selecting the menu, just like the menu instead of changing the clock (instead thats what the light button is doing). …I dismantled everything but can’t find out what is causing this mixed up buttons problem. (not an expert at all in electronics). Any suggestions on what to do?
Hi,
Unfortunately, this guide does not work for the philips HF 3465. The diffuser cannot be removed because the diffuser does not have snap-ins which can be loosened. The diffuser is assembled irreversibly with the grey ring. So you have to destroy the grey ring at several points to have a chance to disassemble the diffuser.
Bad design really. Not environment friendly either.
Is there someone who has disassembled a HF3465?
I have this clock, and it was working fine except the controls (the buttons) don't do anything anymore.
So I'm no longer able to change the time. Any idea how to fix this?
Rob Smeets - 返信
