はじめに
Remove the front cover to access the lens mount, manual and autofocus switch, lens release switch, timer light, and other components.
必要な工具と部品
Retrieve your Pentax K200D, the lens mount cover, and required tools.
Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
9 の人々がこのガイドを完成させました。
