はじめに
The lens can be safely removed in only seven simple steps.
パーツ
パーツは必要ありません。
  1. Remove the following eleven screws securing the covers to the ZS3 Eleven 3 mm Phillips screws Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
    • Remove the following eleven screws securing the covers to the ZS3
      • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown. Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your story with #ImAGenius for a chance to win $100!
    We Are All Geniuses
    Share your repair story with #ImAGenius
  5. Remove the two LCD board ribbon cables out of their sockets.
    • Remove the two LCD board ribbon cables out of their sockets.
  6. Remove the three black screws that surround the lens.
    • Remove the three black screws that surround the lens.
      • 3mm Phillips screws
  7. Using a spudger, flip up the locking flaps on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit. Disconnect the LCD ribbons gently using the spudger. Disconnect the LCD ribbons gently using the spudger.
    • Using a spudger, flip up the locking flaps on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Disconnect the LCD ribbons gently using the spudger.
  8. Using your fingers or a spudger, gently remove the lens mechanism from the rest of the camera. Unlock lens mechanism located on the bottom of the device using your fingers. Be sure to not use excessive force to avoid damaging any parts.
    • Using your fingers or a spudger, gently remove the lens mechanism from the rest of the camera.
      • Unlock lens mechanism located on the bottom of the device using your fingers.
      • Be sure to not use excessive force to avoid damaging any parts.
まとめ
Kellen Ericson
メンバー登録日: 2013年04月17日
10 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S13G60
3 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,604
