パーツ
パーツは必要ありません。
  1. Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Remove the rubbers with a tweezers.
    • Remove the rubbers with a tweezers.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. Remove the 4 screws as shown in the picture
    • Remove the 4 screws as shown in the picture
  6. laid it on a side, use the tool to separate the front and back.
    • laid it on a side, use the tool to separate the front and back.
  7. Put the tool in friction tabs and force down to open the cover as shown in the picture
    • Put the tool in friction tabs and force down to open the cover as shown in the picture
    • Pop it open using your thumbs
  8. Lift the main board over
    • Lift the main board over
  9. pry the connector with finger nails
    • pry the connector with finger nails
まとめ
Van
メンバー登録日: 2010年06月24日
7 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S2G10
4 メンバー
20のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,679
