はじめに
This will guide you on how to disassemble the Palm Centro to get to the logic board.
  1. Press and slide open the battery cover.
    • Press and slide open the battery cover.
  2. Caution: Turn cell phone off before removing battery!
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
    • Phone with battery removed
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
      • Lift the rubber cap at the top right to reveal the sixth screw.
      • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
      • Remove the six screws using the T5 Torx screwdriver.
    • Remove the SIM card so housing can be separated.
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
    • Remove the small plastic insert at the bottom of the phone.
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
      • Be very careful, these electronics are delicate!
    • Separate the logic board from the case by lifting and pulling out the bottom.
まとめ
ある他の人がこのガイドを完成しました。
Chelsea Barackman
メンバー登録日: 2010年04月13日
42 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S15G49
5 メンバー
12のガイドは作成済み
コメント1件
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
Chelsea Barackman - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,923
