メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Use this guide to remove the cover from your Optoma HD20.
パーツ
パーツは指定されていません。
  1. Twist the focal cap clockwise until it is fully extended. Remove the focal cap by pulling it straight out.
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Use a plastic opening tool to gently pry the top cover off of the device.
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
終わりに
7 の人々がこのガイドを完成させました。
Trever
メンバー登録日: 2015年01月22日
1,106 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G23
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 2,119
