メインコンテンツにスキップ
Disassembling Olympus Stylus Tough-8010 Camera Casing
必要な工具と部品
  1. Disassembling Olympus Stylus Tough-8010 Camera Casing, Camera Casing: 手順 1、 3の画像 1 Disassembling Olympus Stylus Tough-8010 Camera Casing, Camera Casing: 手順 1、 3の画像 2 Disassembling Olympus Stylus Tough-8010 Camera Casing, Camera Casing: 手順 1、 3の画像 3
    • Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
    • Take off smaller front cover.
    • Carefully remove larger front cover.
  2. Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 2、 3の画像 1 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 2、 3の画像 2 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 2、 3の画像 3
    • Remove two screws (4.1mm) on the top of the camera using a #000 Phillips head screwdriver.
    • Using a #000 Phillips head screwdriver remove two screws (7.9mm) near the control panel and set aside the metal connector.
    • Although the third photo shows the side panel casing being removed, it is normally secured by a screw under the front framework. You'll need to follow the next two steps to remove the framework and access the screw before you can remove the side casing as shown here.
  3. Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 3、 3の画像 1 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 3、 3の画像 2 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 3、 3の画像 3
    • Using a #000 Philips head screwdriver remove the two screws (4.1mm) on the right side of the camera.
    • Remove two screws (4.1mm) on the bottom of the camera using a #000 head Phillips screwdriver.
    • Remove the single screw (3.2mm) on the front of the camera using a #000 Phillips head.
  4. Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 4、 2の画像 1 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 4、 2の画像 2
    • Carefully remove the font panel piece from the rest of the camera.
    • Carefully remove the top/side plastic piece.
    • If the the camera and flash buttons fall out of their slots set them aside.
    • If you haven't already done so, remove the side casing as mentioned in Step 3. It is secured by a single screw near the bottom corner.
  5. Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 5、 3の画像 1 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 5、 3の画像 2 Disassembling Olympus Stylus Tough-8010 Camera Casing: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove four screws (9.4mm) on the front of the camera using a Phillips #000
    • Use the plastic opening tool to release the holding clip.
    • Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Luke Visser
メンバー登録日: 03/23/15
476 ポイント
4のガイドは作成済み
チーム
Baylor, Team 7-15, Williams Spring 2015 Baylor, Team 7-15, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G15
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 932
