メインコンテンツにスキップ
Disassembling Olympus Stylus Tough 6020 Prerequisite Guide
必要な工具と部品
  1. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Battery: 手順 1、 1の画像 1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 手順 2、 3の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 手順 2、 3の画像 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 手順 2、 3の画像 3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 手順 3、 3の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 手順 3、 3の画像 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 手順 3、 3の画像 3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: 手順 4、 2の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: 手順 4、 2の画像 2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 手順 5、 3の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 手順 5、 3の画像 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 手順 5、 3の画像 3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 手順 6、 3の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 手順 6、 3の画像 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 手順 6、 3の画像 3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 手順 7、 3の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 手順 7、 3の画像 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 手順 7、 3の画像 3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Back Plate: 手順 8、 1の画像 1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 手順 9、 3の画像 1 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 手順 9、 3の画像 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 手順 9、 3の画像 3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Taylor Carabin
メンバー登録日: 04/15/15
259 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 2-6, Matresse Spring 2015 Eastern Washington University, Team 2-6, Matresse Spring 2015人のメンバー
EWU-MATRESSE-S15S2G6
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 768
