はじめに
If the front slider on the camera is cracked or broken, use this guide to remove and replace it.
This guide is also a prerequisite for disassembling other parts of the camera in order to prevent damage to the slider, and to make dis-assembly easier.
必要な工具と部品
Locate the 2 screws on the bottom of the slider.
Remove both screws with a #00 Phillips screwdriver.
ある他の人がこのガイドを完成しました。
2 件のコメント
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
